Can someone recommend a Quick Start that "just works"?
Charles Manning
cdhmanning at gmail.com
Wed Nov 20 22:58:30 UTC 2019
On Thu, Nov 21, 2019 at 11:43 AM Chris Johns <chrisj at rtems.org> wrote:
> On 21/11/19 5:44 am, Charles Manning wrote:
> > 2) Fleshing out
> https://docs.rtems.org/branches/master/user/start/app.html with
> > a brief compile and run example.
> This is an important and missing section and thank you for raising it.
> It has been on a number of TODO lists for a while now and we have not made
> any
> head way. The hard part is how to get the values out of RTEMS you need to
> make
> sure your application's machine flags (ABI) matches your RTEMS BSP and
> then how
> to do this in a way you can use your preferred build system. Another
> factor is
> Sebastian's major task he is working on which is to move building RTEMS to
> a new
> build system, it will effect how the BSP machine flags are exported from
> RTEMS.
> I suppose we could add the most basic approach for a stand alone Makefile.
> Chris
Thanks Chris, that would be helpful.
When you're a complete newbie to a new environment, then just being able to
run through a quick start end-to-end without it falling over is a great
start.
Please understand, I am not throwing rocks at anyone. I am guilty of far
too much bit-rot! I really appreciate the effort that has been put in.
Thanks
Regards
Charles
URL: <http://lists.rtems.org/pipermail/users/attachments/20191121/9a937603/attachment-0001.html>
