installing Doorstop on macOS (for RTEMS use)
Sebastian Huber
Mon Oct 14 05:07:05 UTC 2019
On 13/10/2019 11:15, Chris Johns wrote:
> On 12/10/19 8:08 am, Joel Sherrill wrote:
>> On Fri, Oct 11, 2019, 3:40 PM Gedare Bloom <gedare at rtems.org
>> <mailto:gedare at rtems.org>> wrote:
>> On Thu, Oct 10, 2019 at 8:34 AM Andrew Butterfield
>> <Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>> wrote:
>> > Dear RTEMS Users,
>> > Sebastian Huber asked me to check the availability of Doorstop
>> (https://pypi.org/project/doorstop/) for macOS, and to report my experience
>> on this mailing list.
>> > It is planned to use this for RTEMS requirements in the RTEMS
>> qualification project.
>> I would like to clarify and request confirmation that the use of
>> Doorstop tools will not be required for "casual" RTEMS users.
> It is the view I have. I cannot confirm the view of others.
>> It will
>> be necessary for RTEMS maintainers and for users who want to be
>> involved in the pre-certification effort. Correct?
> Great question. I do not know.
Yes, RTEMS maintainers and users who want to be involved in the
pre-qualification effort will have to work with Doorstop and the
specification items. RTEMS users will not get in touch with Doorstop
directly and don't have to install it.
>> I have identified some roles for using RTEMS and we may want to discuss those at
>> another time.
> Lets then leave this aside until we get to discuss them :)
>> If this is required when you bootstrap RTEMS, I would consider it something
>> required by a casual user given that we expect everyone to do that.
> Then I suggest it does not become part of any bootstrap process.
What do you mean with bootstrap? Calling ./boostrap or
./rtems-bootstrap? My new build system prototype doesn't need such a
step. You can clone the repository and directly start with "./waf
configure". You just have to provide a "build.ini" file, but this is
more or less the same as the old configure command line options.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
