external flash partitions
Kent Dorfman kent.dorfman766 at gmail.com
Mon Oct 14 17:07:35 UTC 2019
this is of concern for me as well.  there is conflicting information on the
web as to whether qspi flash can support filesystem layout or if it must be
handled as discrete pages of mapped memory.  i would like jffs2 on the zynq
qspi flash in my board but not seeing any good info about making it work.
On Oct 14, 2019 9:25 AM, "Catalin Demergian" <demergian at gmail.com> wrote:
> Hello,
> I have RTEMS 4-11.3 running on STM32H7. I also have an external (via QSPI)
> external flash.
> Here is a simple questions for people who done this in the past:
> how can I make partitions on the flash programmatically ?
> or even what RTEMS shell command can I use to create/delete partitions ?
> or do you know any useful doc section ?
> I found this https://docs.rtems.org/releases/rtems-docs-4.11.3/
> bsp-howto/non_volatile_memory.html,
> but it's a bit too generic.
> regards,
> Catalin
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20191014/a56df906/attachment.html>
