external flash partitions
Catalin Demergian demergian at gmail.com
Tue Oct 15 06:37:49 UTC 2019
ok. for me it's done, I can use JFFS2 on my flash already, but is just one
2MB partition.
the question is can I make partitions on my flash ? with a utility or
writing my own code ?
thank you,
Catalin
On Tue, Oct 15, 2019 at 8:56 AM Sebastian Huber <
> On 14/10/2019 19:07, Kent Dorfman wrote:
> > this is of concern for me as well.  there is conflicting information on
> > the web as to whether qspi flash can support filesystem layout or if it
> > must be handled as discrete pages of mapped memory.  i would like jffs2
> > on the zynq qspi flash in my board but not seeing any good info about
> > making it work.
> You can use JFFS2 on anything which supports programming (writing) at
> byte granularity and page erases. The pages must have a uniform size.
> You have to provide three handlers to access your flash during the JFFS2
> mount. For an example see:
> https://git.rtems.org/rtems/tree/testsuites/fstests/jffs2_support/fs_support.c
> https://docs.rtems.org/doxygen/branches/master/group__JFFS2.html
URL: <http://lists.rtems.org/pipermail/users/attachments/20191015/e0c3f950/attachment-0001.html>
