installing Doorstop on macOS (for RTEMS use)
Chris Johns
chrisj at rtems.org
Wed Oct 16 02:52:38 UTC 2019
On 16/10/19 12:57 am, Stanislav Pankevich wrote:
> Hello everyone,
> Maybe I am too late to join this discussion but as far as I followed
> this thread, no one has mentioned using https://github.com/pyenv/pyenv
> to install Python 3 and its dependencies on macOS.
You are not too late and thanks for taking the time to send this email. The
pyenv tools looks nice and I will take a close look.
> Actually, I try to avoid using any of the Ruby, Python or Node system
> installations provided by Apple. Instead, I use pyenv for Python and
> similar projects for other languages.
I can understand this.
> Given that you have a folder where you want to have Python 3
> available, you simply put a .python-version file with the Python
> version you need. After that, you can install and use the needed
> Python 3 version provided to you by pyenv.
> Hope this is useful.
Yes this is useful and I may come back to you if I need a hand. I hope that is OK?
