Getting version of rtems, and writing files
Shane Thomas
codejoy at gmail.com
Mon Oct 21 22:30:33 UTC 2019
I don't see anything that looks like source, found a server that has some
RTEMS folders on it (where the source might of been?) but all that is left
is a .img file, and a folder full of notes on RTEMS. Looks like from what
I see though the version might be 4.6, or 4.7 if that even is in the realm
of reality?
On Mon, Oct 21, 2019 at 4:15 PM Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Oct 21, 2019, 6:00 PM Shane Thomas <codejoy at gmail.com> wrote:
>> I am suspect it is running cexp, it says to type that but typing that
>> gives me a cexp error, though typing help() works and gives this for a help
>> command, which seems to be missing the mount method :(
>> (also Peter Dufault recommended using ikup("mount") but that yielded no
>> command either). cexpr() failed as a command too. The login showed:
>> telnet 10.50.1.111
>> Trying 10.50.1.111...
>> Connected to 10.50.1.111.
>> Escape character is '^]'.
>> Password:
>> [Telnet:] starting cexp on /dev/pty0
>> Type 'cexp.help()' for help (no quotes)
>> cexp.help() though is a lie, but help() produces the following:
>> (Somewhere the source code has to be abound but not sure where, we got no
>> documentation from outgoing IT).
>> alt-rotator>help()
>> Module commands:
>> mod = ld("filename") - load filename object and return handle for
>> unld()
>> lsmod() - list loaded modules and their handle
>> unld(mod) - unload inactive module by its handle
>> Files and directories:
>> cat(filename) - copy file to screen
>> cd(path)
>> copy(filename,filename) - usually used to install files from /rtems
>> to /apo
>> ls()
>> home() - change directory to $HOME. Right now /apo
>> mkdir(path)
>> new_rtems()
>> pwd()
>> rm(filename)
>> System:
>> i
>> memShow
>> reboot
>> stackShow
>> top
>> Network:
>> icmpShow - display ICMP packet statistics
>> ifShow - display statistics gathered by network interfaces
>> ipShow - display IP packet statistics
>> mbufShow - display mbuf statistics
>> routeShow - display the routing table
>> tcpShow - display TCP packet statistics
>> udpShow - display UdP packet statistics
> The bottom groups are names of VxWorks functions which hints there are
> pieces of cexp in there.
> Do you have the source? I don't recall that being answered in the thread.
> Also running strings on the executable might turn up the version string.
>> On Thu, Oct 17, 2019 at 12:07 AM Chris Johns <chrisj at rtems.org> wrote:
>>> On 17/10/19 4:20 am, Shane Thomas wrote:
>>> > I had a question, I inherited a system that uses rtems
>>> Welcome.
>>> > and I am not sure how to
>>> > edit files on that system. There is no vim or vi. I telnet into
>>> them and then
>>> > get a message right away that says:
>>> > cexp.help() for help (which does't work) but help() does show some
>>> commands like
>>> > cat, pwd, home, mod = ld("filename")
>>> The cexp shell is a 3rd party shell package that is not formally part of
>>> RTEMS.
>>> A lot of people use it however I do not and do not know anything about
>>> it. Sorry.
>>> > etc...
>>> > but nothing that would let me edit files that are on that system.
>>> Also no
>>> > ftp/sftp to let me edit locally and then move them to that system. I
>>> am not
>>> > sure the version of rtems this is running even (not sure how to get
>>> that).
>>> > Signed up to this mailing list just to ask this question, not sure what
>>> > else/where else to look.
>>> I use the shell RTEMS provides in the cpukit/libmisc/shell directory and
>>> we have
>>> documented, see docs.rtems.org and click on the shell documents.
>>> To transfer files on to and off boards I set up a machine in the lab as
>>> an NFS
>>> server and then mount it in RTEMS using the mount command:
>>> $ cd /
>>> $ mkdir net
>>> $ mount -t nfs foo:/bar /net
>>> If I need to edit text files on a target I add the `edit` shell command.
>>> It is
>>> OK at performing small editing tasks on the target. Saving, exiting etc
>>> are
>>> mapped to function keys.
>>> I hope this helps.
>>> Chris
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20191021/fc508dc2/attachment.html>
