Getting version of rtems, and writing files
Shane Thomas
codejoy at gmail.com
Tue Oct 22 19:39:25 UTC 2019
I thought maybe . I could remotely mount from my server to the rtems
device, was grabbing at straws but no luck:
sudo mount -t nfs 10.50.1.111:/ testmount/
mount.nfs: Connection timed out
(10.50.1.111 is the rtems device I telnet into)
I am still hunting for the source code on many a various servers.
On Mon, Oct 21, 2019 at 5:14 PM Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Oct 21, 2019, 6:30 PM Shane Thomas <codejoy at gmail.com> wrote:
>> I don't see anything that looks like source, found a server that has some
>> RTEMS folders on it (where the source might of been?) but all that is left
>> is a .img file, and a folder full of notes on RTEMS. Looks like from what
>> I see though the version might be 4.6, or 4.7 if that even is in the realm
>> of reality?
> All of that makes sense and is within the realm of possibility. Both 4.6
> and 4.7 are quite old with both being a decade or more old from memory.
> There are challenges starting from scratch with versions that old primarily
> because the gcc, etc associated with them are correspondingly old.
> I suspect you are looking at a boot server and the .img file is a boot
> image. That's normal for RTEMS. The source was built on another computer
> into that image.
> Any chance there is a software repository somewhere?
> After that, archaeology is an option. Finding out who built the system
> would help you a lot. Is there anyone left who knows?
>> On Mon, Oct 21, 2019 at 4:15 PM Joel Sherrill <joel at rtems.org> wrote:
>>> On Mon, Oct 21, 2019, 6:00 PM Shane Thomas <codejoy at gmail.com> wrote:
>>>> I am suspect it is running cexp, it says to type that but typing that
>>>> gives me a cexp error, though typing help() works and gives this for a help
>>>> command, which seems to be missing the mount method :(
>>>> (also Peter Dufault recommended using ikup("mount") but that yielded no
>>>> command either). cexpr() failed as a command too. The login showed:
>>>> telnet 10.50.1.111
>>>> Trying 10.50.1.111...
>>>> Connected to 10.50.1.111.
>>>> Escape character is '^]'.
>>>> Password:
>>>> [Telnet:] starting cexp on /dev/pty0
>>>> Type 'cexp.help()' for help (no quotes)
>>>> cexp.help() though is a lie, but help() produces the following:
>>>> (Somewhere the source code has to be abound but not sure where, we got
>>>> no documentation from outgoing IT).
>>>> alt-rotator>help()
>>>> Module commands:
>>>> mod = ld("filename") - load filename object and return handle for
>>>> unld()
>>>> lsmod() - list loaded modules and their handle
>>>> unld(mod) - unload inactive module by its handle
>>>> Files and directories:
>>>> cat(filename) - copy file to screen
>>>> cd(path)
>>>> copy(filename,filename) - usually used to install files from
>>>> /rtems to /apo
>>>> ls()
>>>> home() - change directory to $HOME. Right now /apo
>>>> mkdir(path)
>>>> new_rtems()
>>>> pwd()
>>>> rm(filename)
>>>> System:
>>>> i
>>>> memShow
>>>> reboot
>>>> stackShow
>>>> top
>>>> Network:
>>>> icmpShow - display ICMP packet statistics
>>>> ifShow - display statistics gathered by network interfaces
>>>> ipShow - display IP packet statistics
>>>> mbufShow - display mbuf statistics
>>>> routeShow - display the routing table
>>>> tcpShow - display TCP packet statistics
>>>> udpShow - display UdP packet statistics
>>> The bottom groups are names of VxWorks functions which hints there are
>>> pieces of cexp in there.
>>> Do you have the source? I don't recall that being answered in the thread.
>>> Also running strings on the executable might turn up the version string.
>>>> On Thu, Oct 17, 2019 at 12:07 AM Chris Johns <chrisj at rtems.org> wrote:
>>>>> On 17/10/19 4:20 am, Shane Thomas wrote:
>>>>> > I had a question, I inherited a system that uses rtems
>>>>> Welcome.
>>>>> > and I am not sure how to
>>>>> > edit files on that system. There is no vim or vi. I telnet into
>>>>> them and then
>>>>> > get a message right away that says:
>>>>> > cexp.help() for help (which does't work) but help() does show some
>>>>> commands like
>>>>> > cat, pwd, home, mod = ld("filename")
>>>>> The cexp shell is a 3rd party shell package that is not formally part
>>>>> of RTEMS.
>>>>> A lot of people use it however I do not and do not know anything about
>>>>> it. Sorry.
>>>>> > etc...
>>>>> > but nothing that would let me edit files that are on that system.
>>>>> Also no
>>>>> > ftp/sftp to let me edit locally and then move them to that system.
>>>>> I am not
>>>>> > sure the version of rtems this is running even (not sure how to get
>>>>> that).
>>>>> > Signed up to this mailing list just to ask this question, not sure
>>>>> what
>>>>> > else/where else to look.
>>>>> I use the shell RTEMS provides in the cpukit/libmisc/shell directory
>>>>> and we have
>>>>> documented, see docs.rtems.org and click on the shell documents.
>>>>> To transfer files on to and off boards I set up a machine in the lab
>>>>> as an NFS
>>>>> server and then mount it in RTEMS using the mount command:
>>>>> $ cd /
>>>>> $ mkdir net
>>>>> $ mount -t nfs foo:/bar /net
>>>>> If I need to edit text files on a target I add the `edit` shell
>>>>> command. It is
>>>>> OK at performing small editing tasks on the target. Saving, exiting
>>>>> etc are
>>>>> mapped to function keys.
>>>>> I hope this helps.
>>>>> Chris
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20191022/d1ddd12f/attachment-0001.html>
