sparc-rtems5-gdb error
Gedare Bloom
gedare at rtems.org
Tue Sep 24 15:13:11 UTC 2019
On Sat, Sep 21, 2019 at 10:47 PM Niteesh <gsnb.gn at gmail.com> wrote:
> While trying to run the hello world application on the sparc architecture. I faced problems with gdb.
> I followed the exact steps in the rtems quickstart doc. But when trying to the application using gdb I get "Undefined command: sim" when setting the target to the simulator.
> Is it an issue on my side or is something missing in the docs?
(Reposting Jiri's Answer from devel ML)
The sis simulator has been detached from gdb. You can run your
application using sparc-rtems5-sis, or debug it with sparc-rtems5-gdb
using sparc-rtems5-sis as a gdb server. For details, see the sis manual at:
https://gaisler.se/sis/sis.pdf
> Thank you.
> users mailing list
> users at rtems.org
