Write and read functions for RTEMS
Michel Macena
mmacena.eng at gmail.com
Fri Sep 27 05:33:38 UTC 2019
I'm using an ERC32 chip (sparc) . Do you mean the console driver ?
Em ter, 24 de set de 2019 às 20:47, Chris Johns <chrisj at rtems.org> escreveu:
> On 21/9/19 8:39 am, Michel Macena wrote:
> > I noticed in the IO primitive manager section in the RTEMS POSIX guide
> that
> > there are a read and a write function, however the IO guide are not
> finished
> > yet, so I don't know if those functions are in good shape to use. Are
> they ok ?
> > Also is there a tcdrain (from termios.h) equivalent function for RTEMS?
> > I want to make a hardware loop with the board and a pc with linux
> through serial
> > communication. Is there any RTEMS specific functions to send and
> receive data
> > through serial UART ?
> RTEMS supports termios for UART communications. All you need is a driver
> for
> your hardware.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20190927/71e77f58/attachment.html>
