rtems-test with serial device and run.cfg
Chris Johns
chrisj at rtems.org
Wed Apr 8 00:56:56 UTC 2020
On 2020-04-07 23:37, Jan.Sommer at dlr.de wrote:
> I have trouble figuring out how to run rtems-test with a custom command where the output is captured through a serial console.
Does this help ...
https://docs.rtems.org/branches/master/user/testing/consoles.html
> In my ini-file I used
> bsp_tty_dev = /dev/ttyUSB2
> tester = %{_rtscripts}/run.cfg
> bsp_run_cmd = i386-run
> target_off_command = i386-stop
> We have a custom command which prepares the target device.
> The device is connected to the development machine (running Linux) via a serial connection.
Great. I suggest you run `set2net` as documented and have it convert the
tty to TCP.
> Now, the above did not work, since the run.cfg ignores the "bsp_tty_dev" setting and always assumes results via stdout.
> When I change that, rtems-test tries to open the /dev/ttyUSB2 device, but fails to do so with:
> error: opening tty dev: /dev/ttyUSB2: unknown
> Which seems to be caused by this:
> Traceback (most recent call last):
> File "stty.py", line 77, in __init__
> self.fd = open(dev, 'rw')
> ValueError: must have exactly one of create/read/write/append mode
> I am not that familiar with the rtems-test internals. Do I need a different kind of configuration?
> How do others use the "bsp_tty_dev" option (e.g. in the tftp tester)?
The issue with direct tty access and the need to port PySerial to
rtems-test via the rtemstoolkit. The requirements of the rtems-tools
repo make depending on external packages for specific functionality
problematic.
Adding PySerial is a welcome addition to the toolkit but I have not had
the time to complete this task as `ser2net` has been a suitable and
stable alternative. I use ser2net for PC testing from it's serial port.
I hope this helps.
