AW: rtems-test with serial device and run.cfg
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Thu Apr 9 08:14:19 UTC 2020
> -----Ursprüngliche Nachricht-----
> Von: Chris Johns [mailto:chrisj at rtems.org]
> Gesendet: Mittwoch, 8. April 2020 02:57
> An: Sommer, Jan; users at rtems.org
> Betreff: Re: rtems-test with serial device and run.cfg
> > Which seems to be caused by this:
> > Traceback (most recent call last):
> >    File "stty.py", line 77, in __init__
> >      self.fd = open(dev, 'rw')
> > ValueError: must have exactly one of create/read/write/append mode
> > I am not that familiar with the rtems-test internals. Do I need a different
> kind of configuration?
> > How do others use the "bsp_tty_dev" option (e.g. in the tftp tester)?
> The issue with direct tty access and the need to port PySerial to
> rtems-test via the rtemstoolkit. The requirements of the rtems-tools
> repo make depending on external packages for specific functionality
> problematic.
> Adding PySerial is a welcome addition to the toolkit but I have not had
> the time to complete this task as `ser2net` has been a suitable and
> stable alternative. I use ser2net for PC testing from it's serial port.
Since I am going through the documentation again, I have a follow-up question.
In this page https://docs.rtems.org/branches/master/user/testing/configuration.html#configuration-scripts  there is the following example user configuration:
[bsp-special]
bsp              = example-bsp
bsp_tty_dev      = /dev/ttyUSB2
bsp_tty_settings = B115200,~BRKINT,IGNBRK,IGNCR,~ICANON,~ISIG,~IEXTEN,~ECHO,CLOCAL,~CRTSCTS,VMIN=1,VTIME=2
What I understood from your explanation, then this is currently not supported, hence ser2net is needed as a middle-man?
Should that be updated as well then or do you want to keep it for a soon-to-add feature?
Have a nice break,
   Jan
> I hope this helps.
> Chris
