RTEMS 5 Quick Start section 2.7 question
Anders Montonen
Anders.Montonen at iki.fi
Sun Apr 12 17:43:29 UTC 2020
Hi,
I’ve been trying out the RTEMS 5 Quick Start (version 5.ea4c098), and everything worked exactly as written until section 2.7, Test a Board Support Package. Am I correct in that if you followed the RSB BSP build path in section 2.6, the tests are built and run automatically, and that the commands in section 2.7 should/can be run only if you built the BSP manually? If that is the case, then maybe a paragraph to that effect could be added to 2.7?
There’s also a minor typo in section 2.8: The example text when downloading Waf is making the file writable (chmod +w), and not executable (chmod +x).
Regards,
Anders Montonen
