RTEMS 5 Quick Start section 2.7 question
Chris Johns
chrisj at rtems.org
Thu Apr 16 23:24:53 UTC 2020
On 17/4/20 8:03 am, Anders Montonen wrote:
> Hi,
>> On 14 Apr 2020, at 3:46, Chris Johns <chrisj at rtems.org> wrote:
>> The tests can be built with an RSB BSP build option or manually with a configure option. If you have an option present but the tests are not being built then it is a bug.
> In the previous email, I forgot to mention that I’m using the 5.0.0-m2004 snapshot. I’m using the following build command, copied directly from the manual:
> $ ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5 \
>> --target=sparc-rtems5 --with-rtems-bsp=erc32 --with-rtems-tests=yes 5/rtems-kernel
> RTEMS Source Builder - Set Builder, 5.0.0-m2004
> Build Set: 5/rtems-kernel
> config: tools/rtems-kernel-5.cfg
> package: sparc-rtems5-kernel-erc32-1
> download: https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2004/sources/rtems-5.0.0-m2004.tar.xz -> sources/rtems-5.0.0-m2004.tar.xz
> downloading: sources/rtems-5.0.0-m2004.tar.xz - 7.2MB of 7.2MB (100%)
> building: sparc-rtems5-kernel-erc32-1
> sizes: sparc-rtems5-kernel-erc32-1: 2.228GB (installed: 44.410MB)
> cleaning: sparc-rtems5-kernel-erc32-1
> reporting: tools/rtems-kernel-5.cfg -> sparc-rtems5-kernel-erc32-1.txt
> reporting: tools/rtems-kernel-5.cfg -> sparc-rtems5-kernel-erc32-1.xml
> installing: sparc-rtems5-kernel-erc32-1 -> /home/anders/quick-start/rtems/5
> Build Set: Time 0:07:22.715932
> In the rsb-log file, I can see that the test executables are built, but after the build is finished, there are no *.exe files anywhere.
Oh of course, the executables not installed any more. I had forgotten
this. I have created a ticket ... https://devel.rtems.org/ticket/3956
Thanks
