RTEMS 5 Quick Start section 2.7 question
Anders Montonen Anders.Montonen at iki.fi
Thu Apr 16 22:03:20 UTC 2020
Hi,
> On 14 Apr 2020, at 3:46, Chris Johns <chrisj at rtems.org> wrote:
> The tests can be built with an RSB BSP build option or manually with a configure option. If you have an option present but the tests are not being built then it is a bug.
In the previous email, I forgot to mention that I’m using the 5.0.0-m2004 snapshot. I’m using the following build command, copied directly from the manual:
$ ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5 \
>     --target=sparc-rtems5 --with-rtems-bsp=erc32 --with-rtems-tests=yes 5/rtems-kernel
RTEMS Source Builder - Set Builder, 5.0.0-m2004
Build Set: 5/rtems-kernel
config: tools/rtems-kernel-5.cfg
package: sparc-rtems5-kernel-erc32-1
download: https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2004/sources/rtems-5.0.0-m2004.tar.xz -> sources/rtems-5.0.0-m2004.tar.xz
downloading: sources/rtems-5.0.0-m2004.tar.xz - 7.2MB of 7.2MB (100%)
building: sparc-rtems5-kernel-erc32-1
sizes: sparc-rtems5-kernel-erc32-1: 2.228GB (installed: 44.410MB)
cleaning: sparc-rtems5-kernel-erc32-1
reporting: tools/rtems-kernel-5.cfg -> sparc-rtems5-kernel-erc32-1.txt
reporting: tools/rtems-kernel-5.cfg -> sparc-rtems5-kernel-erc32-1.xml
installing: sparc-rtems5-kernel-erc32-1 -> /home/anders/quick-start/rtems/5
Build Set: Time 0:07:22.715932
In the rsb-log file, I can see that the test executables are built, but after the build is finished, there are no *.exe files anywhere.
Regards,
Anders Montonen
