source-builder want to add CFLAG
Gedare Bloom
gedare at rtems.org
Fri Apr 24 14:47:18 UTC 2020
Heinz,
Did you try to modify the source-builder/config/ntp-4-1.cfg file to
add CFLAGS to it? You can see other examples in the same config folder
where CFLAGS are customized that might work to try.
Gedare
On Fri, Apr 24, 2020 at 8:02 AM junkes <junkes at fhi-berlin.mpg.de> wrote:
> I want to add the CFLAG "-DHAVE_MKTIME=1" to the source-builder process
> to build ntp
> ../source-builder/sb-set-builder --log=log_ntp_arm.txt
> --prefix=/home/h1/GSOC/RTEMS/5.0.0-m2003 \
> --host=arm-rtems5 --with-rtems-bsp=xilinx_zynq_a9_qemu net/ntp
> I have already tried several places (cfg-files) but without success.
> Danke,
> Heinz
> users mailing list
> users at rtems.org
