source-builder want to add CFLAG
Heinz Junkes
junkes at fhi-berlin.mpg.de
Fri Apr 24 15:40:32 UTC 2020
Great, thanks. Now I have a new error, but the setting of CFLAG worked.
I had always done "something" wrong and then didn't even look at the examples anymore.
Danke Heinz
> On 24. Apr 2020, at 16:47, Gedare Bloom <gedare at rtems.org> wrote:
> Heinz,
> Did you try to modify the source-builder/config/ntp-4-1.cfg file to
> add CFLAGS to it? You can see other examples in the same config folder
> where CFLAGS are customized that might work to try.
> Gedare
> On Fri, Apr 24, 2020 at 8:02 AM junkes <junkes at fhi-berlin.mpg.de> wrote:
>> I want to add the CFLAG "-DHAVE_MKTIME=1" to the source-builder process
>> to build ntp
>> ../source-builder/sb-set-builder --log=log_ntp_arm.txt
>> --prefix=/home/h1/GSOC/RTEMS/5.0.0-m2003 \
>> --host=arm-rtems5 --with-rtems-bsp=xilinx_zynq_a9_qemu net/ntp
>> I have already tried several places (cfg-files) but without success.
>> Danke,
>> Heinz
>> users mailing list
>> users at rtems.org
