using libdebugger
Chris Johns
chrisj at rtems.org
Thu Apr 30 00:14:31 UTC 2020
On 29/4/20 6:37 pm, Mario Palomares wrote:
> Hi everybody,
> I'have seen in the documentation, Users Manual/Debugging, that there is
> a possibility to do remote debugging with the libdebugger library. But
> there, it only mentions the possibility, it doesn´t explain how to set
> it up.
> I'have searched for some documentation about it and found this:
> https://docs.rtems.org/releases/rtemsdocs-4.7.1/share/rtems/html/rgdb_specs/rgdb_specs00011.html
> https://docs.rtems.org/releases/4.5.1-pre3/rtemsdoc/pdf/rtems_gdb.pdf
> I have also checked the header files in the source tree, but still need
> some guidance.
> Could explain a little about this or reference me some useful documentation?
Only a limited number of architectures are supported and some like the
ARM thumb mode are experimental. I do apologise for the lack of
documentation, most of the recent work is unfunded, i.e. ARM support,
and any time I have is spent on the code.
The set up is simple as the test code in libbsd shows:
https://git.rtems.org/rtems-libbsd/tree/testsuite/debugger01/test_main.c
Note:
a) Add `-ldebugger` to your list of libraries when linking your application.
b) Make sure you have the network running for the TCP transport before
starting the debugger.
Setup
1. Optionally add the debugger shell command using:
rtems_shell_add_cmd_struct(&rtems_shell_DEBUGGER_Command);
The command lets you manage the debug server from a shell. It is
useful when you need to see something in a running system that does
not start the debug server by default.
The command is `debugger`. Enter is to see the current status:
# debugger
RTEMS debugger is running
Use the following options with the `start` command to start the
debug server:
-v:
Set trace to verbose
-R <transport>
Set the remote transport, currently only `tcp` supported
-d <device>
Set the device. For `tcp` this is the listen port for the
server
-t <timeout>
Set the debugger timeout
-P <priority>
Set the debug server's priority (classic API)
-l <output>
Set the debug server's output. Can be:
stdout
stderr
kernel
# debugger -v -d 3456 start
Use `stop` to stop the debugger:
# debugger stop
2. Register the remote transport with the debugger:
r = rtems_debugger_register_tcp_remote();
if (r < 0)
die("failed");
3. Optionally start the debugger or use the shell command:
rtems_printer printer;
rtems_print_printer_fprintf(&printer, stdout);
r = rtems_debugger_start("tcp", "1122", 3, 1, &printer);
if (r < 0)
die("failed");
4. Once running on the target connect with gdb using:
arm-rtems5-gdb myapp.exe
GNU gdb (GDB) 9.1
<content removed>
(gdb) target remote 192.168.1.200:1122
Remote debugging using 192.168.1.200:1122
_User_extensions_Thread_switch (executing=0x0, heir=<optimized out>)
at /opt/work/rtems/rtems.git/cpukit/include/rtems/score/userextimpl.h:379
379 if ( node != tail ) {
5. The gdb thread commands can show you what is running and you can
switch threads:
(gdb) info thread
Id Target Id
Frame
* 1 Thread 1.167837697 (UI1 (0a010001), priority(c:235 r:235),
stack(s: 65536 a:0xa162a0), state(EV:SUSP))
_User_extensions_Thread_switch (executing=0x0, heir=<optimized out>) at
2 Thread 1.167837698 (SR02 (0a010002), priority(c:165 r:165),
stack(s: 16384 a:0xa2ffb8), state(CV:SUSP))
/opt/work/si/rtems/rtems.git/cpukit/include/rtems/score/userextimpl.h:379
(gdb) thread 2
[Switching to thread 2 (Thread 1.167837698)]
#0 _User_extensions_Thread_switch (executing=0x0, heir=<optimized
out>) at
Thread specific breakpoints is not supported.
6. To debugging application initialisation problems, initialise the
network stack, start the debugger, then sit in a loop while a volatile
variable is `false` sleeping for a second. Connect with gdb and set the
variable to `true`, set any further breakpoints and then `continue`.
Note: This is a software based debugging solution for applications. It
has limitations on what it can debug and some bugs will effect the debug
server and it's operation. For driver and hardware debugging a hardware
based debug solution is best.
I hope this helps.
