No subject
Mario Palomares palomares.mario14 at gmail.com
Wed Apr 29 08:37:46 UTC 2020
Hi everybody,
I'have seen in the documentation, Users Manual/Debugging, that there is a
possibility to do remote debugging with the libdebugger library. But there,
it only mentions the possibility, it doesn´t explain how to set it up.
I'have searched for some documentation about it and found this:
https://docs.rtems.org/releases/rtemsdocs-4.7.1/share/rtems/html/rgdb_specs/rgdb_specs00011.html
https://docs.rtems.org/releases/4.5.1-pre3/rtemsdoc/pdf/rtems_gdb.pdf
I have also checked the header files in the source tree, but still need
some guidance.
Could explain a little about this or reference me some useful documentation?
Thanks,
Mario
URL: <http://lists.rtems.org/pipermail/users/attachments/20200429/488d0d86/attachment.html>
