source builder, bsp arch settings
Heinz Junkes junkes at fhi-berlin.mpg.de
Thu Apr 30 10:19:34 UTC 2020
Hello, Chris,
thanks for testing it right away. It was a stupid mistake on my part, of course.
To get around the build error I had to define macros in the build-script.
“-DHAVE_MKTIME -DHAVE_TIMEGM”
Unfortunately, configure --extra-cflags does not work as expected
So I set CFLAGS before the call to configure and forgot to append the existing flags ${CFLAGS} :-(
Heinz
> On 30. Apr 2020, at 01:33, Chris Johns <chrisj at rtems.org> wrote:
> On 29/4/20 8:03 pm, Heinz Junkes wrote:
>> unfortunately i can't really get along with the source-builder/sb-set-builder.
> Can you build the package by manually? This is the recommended first step. The RSB is just a means to capture those manual steps.
>> For example, I want to build ntp for xilinx_zynq_a9_qemu using the command line:
>> (in rtems-source-builder-5.0.0-m2003/rtems)
> This is a snapshot release which means it can break. While we try as best we can there is no guarantee a release snapshot will work. Having said that I am pleased you are testing it and reporting problems.
>> ../source-builder/sb-set-builder —log=log_ntp_arm.txt —prefix=/home/h1/GSOC/RTEMS/5.0.0-m2003 \
>> —host=arm=rtems5 —with-rtems-bsp=xilinx_zynq_a9_qemu net/ntp
> I have attempted to build net/ntp for the same BSP from the RSB master and I am seeing this following error:
> ../../ntp-4.2.6p5/libntp/mktime.c:67:2: error:
> #error libntp supplied mktime()/timegm() do not support 64-bit time_t
> Do you have something else you are building?
>> I have assumed that the compiler flags for xilinx_zynq_a9_qemu are taken over by the specification for which BSP
>> I want to build this.
>> E.g. “-march-armv7-a”
> Do you mean "-march=armv7-a"?
>> Unfortunately, the compilation of ntp does not work, because __ARM_ARCH is not set to “7"
>> but remains defined at the default value of "4”.
>> Because of the missing CFLAGS for the  xilinx_zynq_a9_qemu architecture?
> Are you saying the compile command line flags do not have the correct `-march=armv7-a` option?
> The build I just did that failed has the correct set of machine flags for a Zynq (Cortex-A9):
> -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9
> And this gives me:
> $ arm-rtems5-gcc -dM -E -march=armv7-a -mthumb -mfpu=neon \
>   -mfloat-abi=hard -mtune=cortex-a9 - < /dev/null | grep '__ARM_ARCH '
> #define __ARM_ARCH 7
> Chris
