users Digest, Vol 167, Issue 8
Zacchaeus Liang zliang111 at gmail.com
Tue Aug 11 01:27:10 UTC 2020
It says that there is not supplied executable
zack
Il giorno lun 10 ago 2020 alle ore 21:10 Vijay Kumar Banerjee <
vijay at rtems.org> ha scritto:
> Hi Zack,
> I have posted a comment below...
> On Tue, Aug 11, 2020 at 5:54 AM Zacchaeus Liang <zliang111 at gmail.com>
> wrote:
> > I tried to add the prefix and i had the prefix  with this
> > rtems-test --rtems-bsp=i386-rtems5
> --rtems-tools=$HOME/development/rtems/5
> --rtems-prefix=$HOME/development/rtems/5
> > i get the same error. Was the prefix correct based on the instructions?
> > Thanks
> > zack
> > Il giorno lun 10 ago 2020 alle ore 00:31 Niteesh G. S. <
> niteesh.gs at gmail.com> ha scritto:
> >> Hello,
> >>> Hello,
> >>> I'm Zack and I'm currently finishing up my university degree in comp
> sci.
> >>> I'm really interested in aviation and aerospace systems. I want to get
> into
> >>> rtems to learn more about rtos and contribute to rtems !
> >>> Currently I'm trying to build rtems and test and bsp. Hoping to then
> >>> contribute. I followed one of you GSOC student's tutorials and tried
> to go
> >>> ahead. I'm trying to build the test the bsp right now.
> >>> here is his blog post
> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
> >>> I tried to run the bsp testing like this and it says the ini file is
> not
> >>> found.  Is this the right bsp argument?  After this i'm going to try to
> >>> build an application and would like to know the right path to install
> it.
> >>> Any tips on looking for easy things to learn to patch? Thanks in
> advance i
> >>> know it's a handful for questions!
> >>> zakonrockets at zakonrockets-Inspiron-15-7000-Gaming
> :~/development/rtems/kernels-5/pcp-386$
> >>> RTEMS Testing - Tester, 5.0.not_released
> >>>  Command Line: /home/zakonrockets/development/rtems/5/bin/rtems-test
> --rtems-bsp option should have the bsp and not the architecture.
> Please try --rtems-bsp=pc-qemu
URL: <http://lists.rtems.org/pipermail/users/attachments/20200810/6c50f722/attachment.html>
