users Digest, Vol 167, Issue 8
Vijay Kumar Banerjee vijay at rtems.org
Tue Aug 11 01:31:20 UTC 2020
On Tue, Aug 11, 2020 at 6:57 AM Zacchaeus Liang <zliang111 at gmail.com> wrote:
> It says that there is not supplied executable
Looks like you're in the right direction.
Add the location to the samples directory to the command line and
it'll work. The location will be in the bsp build location.
something like pc-386/i386-rtems5/c/pc386/testsuites/samples
Best regards,
Vijay
> zack
> Il giorno lun 10 ago 2020 alle ore 21:10 Vijay Kumar Banerjee <vijay at rtems.org> ha scritto:
>> Hi Zack,
>> I have posted a comment below...
>> On Tue, Aug 11, 2020 at 5:54 AM Zacchaeus Liang <zliang111 at gmail.com> wrote:
>> > I tried to add the prefix and i had the prefix  with this
>> > rtems-test --rtems-bsp=i386-rtems5 --rtems-tools=$HOME/development/rtems/5 --rtems-prefix=$HOME/development/rtems/5
>> > i get the same error. Was the prefix correct based on the instructions?
>> > Thanks
>> > zack
>> > Il giorno lun 10 ago 2020 alle ore 00:31 Niteesh G. S. <niteesh.gs at gmail.com> ha scritto:
>> >> Hello,
>> >>> Hello,
>> >>> I'm Zack and I'm currently finishing up my university degree in comp sci.
>> >>> I'm really interested in aviation and aerospace systems. I want to get into
>> >>> rtems to learn more about rtos and contribute to rtems !
>> >>> Currently I'm trying to build rtems and test and bsp. Hoping to then
>> >>> contribute. I followed one of you GSOC student's tutorials and tried to go
>> >>> ahead. I'm trying to build the test the bsp right now.
>> >>> here is his blog post
>> >>> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
>> >>> I tried to run the bsp testing like this and it says the ini file is not
>> >>> found.  Is this the right bsp argument?  After this i'm going to try to
>> >>> build an application and would like to know the right path to install it.
>> >>> Any tips on looking for easy things to learn to patch? Thanks in advance i
>> >>> know it's a handful for questions!
>> >>> zakonrockets at zakonrockets-Inspiron-15-7000-Gaming:~/development/rtems/kernels-5/pcp-386$
>> >>> RTEMS Testing - Tester, 5.0.not_released
>> >>>  Command Line: /home/zakonrockets/development/rtems/5/bin/rtems-test
>> --rtems-bsp option should have the bsp and not the architecture.
>> Please try --rtems-bsp=pc-qemu
