users Digest, Vol 167, Issue 8
Zacchaeus Liang zliang111 at gmail.com
Thu Aug 13 00:11:39 UTC 2020
I got the test to run but there were tons of errors. I haven't touched any
of the source or really dived into it.
RTEMS Testing - Tester, 5.0.not_released
 Command Line: /home/zakonrockets/development/rtems/5/bin/rtems-test
--rtems-tools=/home/zakonrockets/development/rtems/5 --rtems-bsp=pc-qemu
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites
--rtems-prefix=/home/zakonrockets/development/rtems/5
 Host: Linux zakonrockets-Inspiron-15-7000-Gaming 5.3.0-64-generic
#58-Ubuntu SMP Fri Jul 10 19:33:51 UTC 2020 x86_64
 Python: 3.7.5 (default, Apr 19 2020, 20:18:17) [GCC 9.2.1 20191008]
Host: Linux-5.3.0-64-generic-x86_64-with-Ubuntu-19.10-eoan (Linux
zakonrockets-Inspiron-15-7000-Gaming 5.3.0-64-generic #58-Ubuntu SMP Fri
Jul 10 19:33:51 UTC 2020 x86_64 x86_64)
[ 3/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | i386/pc686:
cdtest.exe
[ 6/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | i386/pc686: hello.exe
[ 4/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  | i386/pc686:
cxx_iostream.exe
error: qemu.cfg:85: execute failed: qemu-system-i386 -no-reboot -nographic
-monitor none -serial stdio -append --console=/dev/com1 -kernel
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/hello.exe:
exit-code:2
exit-code:2
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/cxx_iostream.exe:
exit-code:2
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/cdtest.exe:
exit-code:2
exit-code:2
warning: switched to dry run due to errors
exit-code:2
[ 2/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:3  W:0  | i386/pc686:
capture.exe
[ 8/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:3  W:0  | i386/pc686:
minimum.exe
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/capture.exe:
exit-code:2
exit-code:2
[ 7/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  | i386/pc686:
loopback.exe
[ 1/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  | i386/pc686:
base_sp.exe
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/minimum.exe:
exit-code:2
exit-code:2
[ 5/13] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  | i386/pc686:
fileio.exe
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/loopback.exe:
exit-code:2
exit-code:2
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/base_sp.exe:
exit-code:2
exit-code:2
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/fileio.exe:
exit-code:2
exit-code:2
base_sp.exe
Result: invalid    Time: 0:00:00.017795 base_sp.exe
=>  run: qemu-system-i386 -no-reboot -nographic -monitor none -serial stdio
capture.exe
Result: invalid    Time: 0:00:00.014453 capture.exe
cdtest.exe
Result: invalid    Time: 0:00:00.054058 cdtest.exe
cxx_iostream.exe
Result: invalid    Time: 0:00:00.026283 cxx_iostream.exe
fileio.exe
Result: invalid    Time: 0:00:00.010072 fileio.exe
Result: invalid    Time: 0:00:00.035287 hello.exe
loopback.exe
Result: invalid    Time: 0:00:00.029105 loopback.exe
minimum.exe
[10/13] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  | i386/pc686:
paranoia.exe
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/paranoia.exe:
exit-code:2
exit-code:2
[13/13] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:8  W:0  | i386/pc686:
unlimited.exe
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/unlimited.exe:
exit-code:2
exit-code:2
[11/13] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:9  W:0  | i386/pc686: pppd.exe
[12/13] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:9  W:0  | i386/pc686:
ticker.exe
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/pppd.exe:
exit-code:2
exit-code:2
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/ticker.exe:
exit-code:2
exit-code:2
[ 9/13] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:11 W:0  | i386/pc686: nsecs.exe
/home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites/samples/nsecs.exe:
exit-code:2
exit-code:2
Result: invalid    Time: 0:00:00.004524 nsecs.exe
paranoia.exe
Result: invalid    Time: 0:00:00.006776 paranoia.exe
Result: invalid    Time: 0:00:00.018013 pppd.exe
ticker.exe
Result: invalid    Time: 0:00:00.008560 ticker.exe
unlimited.exe
Result: invalid    Time: 0:00:00.006357 unlimited.exe
Passed:         1
Failed:         0
User Input:     0
Expected Fail:  0
Indeterminate:  0
Benchmark:      0
Timeout:        0
Invalid:       12
Wrong Version:  0
Wrong Build:    0
Wrong Tools:    0
Total:         13
Invalid:
 cdtest.exe
 hello.exe
 cxx_iostream.exe
 capture.exe
 loopback.exe
 base_sp.exe
 fileio.exe
 paranoia.exe
 unlimited.exe
 pppd.exe
 ticker.exe
 nsecs.exe
Average test time: 0:00:00.060904
Testing time     : 0:00:00.791756
regards
zack
Il giorno lun 10 ago 2020 alle ore 21:51 Vijay Kumar Banerjee <
vijay at rtems.org> ha scritto:
> On Tue, Aug 11, 2020 at 7:14 AM Zacchaeus Liang <zliang111 at gmail.com>
> wrote:
> > Do i add it as an argument and what is the argument name (didn't reply
> all sorry?
> You don't need a separate option just add the location with the
> command line you're using. Something like this:
> rtems-test \
> --rtems-tools=$HOME/development/rtems/5 \
> --rtems-bsp=lpc-qemu \
> $HOME/development/rtems/kernel/pc386/i386-rtems5/c/pc386/testsuites/samples
> > Thanks
> > zack
> > Il giorno lun 10 ago 2020 alle ore 21:31 Vijay Kumar Banerjee <
> >> On Tue, Aug 11, 2020 at 6:57 AM Zacchaeus Liang <zliang111 at gmail.com>
> wrote:
> >> > It says that there is not supplied executable
> >> Looks like you're in the right direction.
> >> Add the location to the samples directory to the command line and
> >> it'll work. The location will be in the bsp build location.
> >> something like pc-386/i386-rtems5/c/pc386/testsuites/samples
> >> Best regards,
> >> Vijay
> >> > zack
> >> > Il giorno lun 10 ago 2020 alle ore 21:10 Vijay Kumar Banerjee <
> >> >> Hi Zack,
> >> >> I have posted a comment below...
> >> >> On Tue, Aug 11, 2020 at 5:54 AM Zacchaeus Liang <zliang111 at gmail.com>
> wrote:
> >> >> > I tried to add the prefix and i had the prefix  with this
> >> >> > rtems-test --rtems-bsp=i386-rtems5
> --rtems-prefix=$HOME/development/rtems/5
> >> >> > i get the same error. Was the prefix correct based on the
> instructions?
> >> >> > Thanks
> >> >> > zack
> >> >> > Il giorno lun 10 ago 2020 alle ore 00:31 Niteesh G. S. <
> niteesh.gs at gmail.com> ha scritto:
> >> >> >> Hello,
> >> >> >>> Hello,
> >> >> >>> I'm Zack and I'm currently finishing up my university degree in
> comp sci.
> >> >> >>> I'm really interested in aviation and aerospace systems. I want
> to get into
> >> >> >>> rtems to learn more about rtos and contribute to rtems !
> >> >> >>> Currently I'm trying to build rtems and test and bsp. Hoping to
> then
> >> >> >>> contribute. I followed one of you GSOC student's tutorials and
> tried to go
> >> >> >>> ahead. I'm trying to build the test the bsp right now.
> >> >> >>> here is his blog post
> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
> >> >> >>> I tried to run the bsp testing like this and it says the ini
> file is not
> >> >> >>> found.  Is this the right bsp argument?  After this i'm going to
> try to
> >> >> >>> build an application and would like to know the right path to
> install it.
> >> >> >>> Any tips on looking for easy things to learn to patch? Thanks in
> advance i
> >> >> >>> know it's a handful for questions!
> >> >> >>> zakonrockets at zakonrockets-Inspiron-15-7000-Gaming
> :~/development/rtems/kernels-5/pcp-386$
> >> >> >>>  Command Line:
> >> >> --rtems-bsp option should have the bsp and not the architecture.
> >> >> Please try --rtems-bsp=pc-qemu
URL: <http://lists.rtems.org/pipermail/users/attachments/20200812/bc9337d3/attachment-0001.html>
