users Digest, Vol 167, Issue 8
Vijay Kumar Banerjee
vijay at rtems.org
Tue Aug 11 01:51:35 UTC 2020
On Tue, Aug 11, 2020 at 7:14 AM Zacchaeus Liang <zliang111 at gmail.com> wrote:
> Do i add it as an argument and what is the argument name (didn't reply all sorry?
You don't need a separate option just add the location with the
command line you're using. Something like this:
rtems-test \
--rtems-tools=$HOME/development/rtems/5 \
--rtems-bsp=lpc-qemu \
$HOME/development/rtems/kernel/pc386/i386-rtems5/c/pc386/testsuites/samples
> Thanks
> zack
> Il giorno lun 10 ago 2020 alle ore 21:31 Vijay Kumar Banerjee <vijay at rtems.org> ha scritto:
>> On Tue, Aug 11, 2020 at 6:57 AM Zacchaeus Liang <zliang111 at gmail.com> wrote:
>> > It says that there is not supplied executable
>> Looks like you're in the right direction.
>> Add the location to the samples directory to the command line and
>> it'll work. The location will be in the bsp build location.
>> something like pc-386/i386-rtems5/c/pc386/testsuites/samples
>> Best regards,
>> Vijay
>> > zack
>> > Il giorno lun 10 ago 2020 alle ore 21:10 Vijay Kumar Banerjee <vijay at rtems.org> ha scritto:
>> >> Hi Zack,
>> >> I have posted a comment below...
>> >> On Tue, Aug 11, 2020 at 5:54 AM Zacchaeus Liang <zliang111 at gmail.com> wrote:
>> >> > I tried to add the prefix and i had the prefix with this
>> >> > rtems-test --rtems-bsp=i386-rtems5 --rtems-tools=$HOME/development/rtems/5 --rtems-prefix=$HOME/development/rtems/5
>> >> > i get the same error. Was the prefix correct based on the instructions?
>> >> > Thanks
>> >> > zack
>> >> > Il giorno lun 10 ago 2020 alle ore 00:31 Niteesh G. S. <niteesh.gs at gmail.com> ha scritto:
>> >> >> Hello,
>> >> >>> Hello,
>> >> >>> I'm Zack and I'm currently finishing up my university degree in comp sci.
>> >> >>> I'm really interested in aviation and aerospace systems. I want to get into
>> >> >>> rtems to learn more about rtos and contribute to rtems !
>> >> >>> Currently I'm trying to build rtems and test and bsp. Hoping to then
>> >> >>> contribute. I followed one of you GSOC student's tutorials and tried to go
>> >> >>> ahead. I'm trying to build the test the bsp right now.
>> >> >>> here is his blog post
>> >> >>> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
>> >> >>> I tried to run the bsp testing like this and it says the ini file is not
>> >> >>> found. Is this the right bsp argument? After this i'm going to try to
>> >> >>> build an application and would like to know the right path to install it.
>> >> >>> Any tips on looking for easy things to learn to patch? Thanks in advance i
>> >> >>> know it's a handful for questions!
>> >> >>> zakonrockets at zakonrockets-Inspiron-15-7000-Gaming:~/development/rtems/kernels-5/pcp-386$
>> >> >>> RTEMS Testing - Tester, 5.0.not_released
>> >> >>> Command Line: /home/zakonrockets/development/rtems/5/bin/rtems-test
>> >> --rtems-bsp option should have the bsp and not the architecture.
>> >> Please try --rtems-bsp=pc-qemu
