Corrupted test marker with u-boot and zynq
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Thu Aug 20 06:59:33 UTC 2020
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: Thursday, August 20, 2020 5:43 AM
> To: Sommer, Jan; joel at rtems.org
> Cc: users at rtems.org
> Subject: Re: Corrupted test marker with u-boot and zynq
> >> Sent: Wednesday, August 19, 2020 1:25 AM
> >> I assume you are using the default baudrate of 115200?
> >> Is this custom hardware?
> > It's a SoM from Trenz (e.g. here: https://shop.trenz-electronic.de/en/TE0715-
> 04-15-1I-SoC-Module-with-Xilinx-Zynq-XC7Z015-1CLG485I-1-GByte-DDR3L-4-x-
> 5-cm) which sits on the 0706 Carrier-board.
> > I compiled rtems with the following to set the clock values in line with
> vivado:
> > ../rtems-5.0.0-m2006-2/configure --target=arm-rtems5 --
> prefix=~/rtems/bsps/5/arm --disable-networking --enable-
> rtemsbsp=xilinx_zynq_zedboard --enable-cxx --enable-posix
> ZYNQ_CLOCK_UART=100000000
> BSP_ARM_A9MPCORE_PERIPHCLK=333333333U
> ZYNQ_CLOCK_CPU_1X=111111111U BSP_CONSOLE_MINOR=0 --enable-tests
> I use weak functions to handle the clocks.
Thanks, that's a good tip.
> >>> Would this be a solution which could be accepted as a patch?
> >> I do not see any harm in the change however I would like to know what
> the
> >> difference between your set up and mine is. Your output is missing ...
> >> ## Transferring control to RTEMS (at address 00104000) ...
> > Ah, yes.
> > I just tried with a bare metal hello_world from Xilinx and there this line
> appears, but not when I load rtems applications.
> > That's weird.
> > We have u-boot compiled from the Xilinx repositories: U-Boot 2019.01 (Jul
> 16 2020 - 14:44:10 +0000) Xilinx Zynq ZC702
> I use the u-boot repo and not the vendors.
We can try if that changes anything, when some people are back from vacation.
> I check the TRM and the string is about 60 characters and the FIFO is 64 bytes
> so it is possible the whole string is in the buffer.
> Please create a patch and send to devel at rtems.org.
Will do.
Best regards,
   Jan
> Thanks
> Chris
