RTEMS 5.1 RC2 Available
Karel Gardas karel.gardas at centrum.cz
Mon Aug 24 22:16:22 UTC 2020
On 8/14/20 11:19 PM, Chris Johns wrote:
> Hello,
> RTEMS 5.1 RC2 is available for testing. You can find the release at:
>   https://ftp.rtems.org/pub/rtems/releases/5/rc/5.1-rc2
> Please report your successes or problems here.
Playing with various ppc bsps and also with i386/pc686 bsp build using
rsb. On pc686, I see those failures:
Passed:        559
Failed:          6
User Input:      6
Expected Fail:   0
Indeterminate:   0
Benchmark:       3
Timeout:        14
Invalid:         5
Wrong Version:   0
Wrong Build:     0
Wrong Tools:     0
Total:         593
Failures:
 dl06.exe
 psx12.exe
 psxfenv01.exe
 spfatal30.exe
 sptimecounter02.exe
 tmcontext01.exe
User Input:
 capture.exe
 dl10.exe
 fileio.exe
 monitor.exe
 termios.exe
 top.exe
Benchmark:
 dhrystone.exe
 linpack.exe
 whetstone.exe
Timeouts:
 cdtest.exe
 cxx_iostream.exe
 dl05.exe
 psxintrcritical01.exe
 spfatal26.exe
 spintrcritical06.exe
 spintrcritical07.exe
 spintrcritical11.exe
 spintrcritical12.exe
 spintrcritical13.exe
 spintrcritical14.exe
 spintrcritical15.exe
 spintrcritical18.exe
 spintrcritical24.exe
Invalid:
 spfatal09.exe
 spfatal12.exe
 spinternalerror01.exe
 spstkalloc02.exe
 sptimecounter01.exe
Average test time: 0:00:00.765811
Testing time     : 0:07:34.125646
this is when using Qemu 4.1 as build by rsb and test started with:
$ rtems-test --rtems-bsp=pc-qemu --rtems-tools=$HOME/sfw/rtems/51rc2/
$HOME/sfw/rtems/51rc2/i386-rtems5/pc686/tests/
So far no luck with ppc on qemu.
BTW: RTEMS docs looks fantastics, although still a bit outdated by
refering to RTEMS 4.x on some places -- mostly after quick start
paragraph. Also is there any reason pcx86 BSP is not documented at all?
Looks a bit pity as it's probably most available hardware -- still...
Thanks!
Karel
> You can also raise a ticket if you prefer. Please select the 5.1 milestone.
> The RC is now correctly named with a 2 number version number.
> The changes since RC1 are:
>  https://devel.rtems.org/query?changetime=Jun+26%2C+2020..&milestone=5.1&group=resolution&order=id
> Thanks
> Chris
> users mailing list
> users at rtems.org
