BSP missing
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Tue Aug 25 21:04:00 UTC 2020
> I followed this tutorial from a GSOC student. https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
> This is how i've configured it.
> $HOME/development/rtems/rtems-5/configure --target=i386-rtems5 --enable-rtemsbsp=pc386 --enable-tests=samples --prefix=$HOME/development/rtems/5 --enable-cxx --enable-networking --enable-posix
Here you configure a build of the pc386 BSP.
> And i was able to test it with
> home/zakonrockets/development/rtems/5/bin/rtems-test --rtems-tools=/home/zakonrockets/development/rtems/5 --rtems-bsp=pc-qemu /home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites --rtems-prefix=/home/zakonrockets/development/rtems/5
> I don't quite know the name of my BSP currently I think it's pc 386 but it's not found. Am a correct to assume that it is?
Yes, it should be the pc386 BSP.
What do you mean by it is not found? If you search for "ticker.exe" do you find the testsuites/samples directory which should contain it?
Best regards,
   Jan
> Il giorno mar 25 ago 2020 alle ore 16:17 <Jan.Sommer at dlr.de> ha scritto:
> > -----Original Message-----
> > From: users [mailto:users-bounces at rtems.org] On Behalf Of Gedare Bloom
> > Sent: Tuesday, August 25, 2020 9:15 PM
> > To: Zacchaeus Liang
> > Cc: RTEMS Users RTEMS
> > Subject: Re: BSP missing
> > Hi Zack,
> > On Tue, Aug 25, 2020 at 1:02 PM Zacchaeus Liang <zliang111 at gmail.com>
> > wrote:
> > > So I was able to build the bsp and all of the tests pass. I'm currently trying
> > to build the hello world app.
> > > zakonrockets at zakonrockets-Inspiron-15-7000-
> > Gaming:~/development/app/hello$ ./waf configure --
> > rtems=$HOME/development/rtems/5 --rtems-bsp=pc-qemu
> > > Setting top to                           :
> > /home/zakonrockets/development/app/hello
> > > Setting out to                           :
> > /home/zakonrockets/development/app/hello/build
> > > No valid arch/bsps found
> > > (complete log in
> > /home/zakonrockets/development/app/hello/build/config.log)
> > Is this from rtems-examples.git? Or something else?
> pc-qemu exists in a configuration for the rtems-tester, but it is only  a different way to execute the pc686 binaries on qemu instead via tftp on actual hardware (for more see here: https://git.rtems.org/rtems-tools/tree/tester/rtems/testing/bsps/pc-qemu.ini).
> I haven't encountered it somewhere else.
> Best regards,
>    Jan
> > Please check out rtems-examples.git/README.waf for some assistance on
> > how to use the rtems_waf to build an application.
> > > Thanks
> > > Zack
> > > _______________________________________________
> > > users mailing list
> > > users at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
> > users at rtems.org
