BSP missing
Zacchaeus Liang zliang111 at gmail.com
Thu Aug 27 01:30:31 UTC 2020
'm currently getting an error that  the arch and the bsp is not found
zakonrockets at zakonrockets-Inspiron-15-7000-Gaming:~/development/app/hello$
./waf configure --rtems=$HOME/development/rtems/5 --rtems-bsp=pc386
Setting top to                           :
/home/zakonrockets/development/app/hello
Setting out to                           :
/home/zakonrockets/development/app/hello/build
No valid arch/bsps found
(complete log in /home/zakonrockets/development/app/hello/build/config.log)
thanks zack
Il giorno mar 25 ago 2020 alle ore 17:04 <Jan.Sommer at dlr.de> ha scritto:
> > I followed this tutorial from a GSOC student.
> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
> > This is how i've configured it.
> > $HOME/development/rtems/rtems-5/configure --target=i386-rtems5
> --enable-rtemsbsp=pc386 --enable-tests=samples
> --prefix=$HOME/development/rtems/5 --enable-cxx --enable-networking
> --enable-posix
> Here you configure a build of the pc386 BSP.
> > And i was able to test it with
> > home/zakonrockets/development/rtems/5/bin/rtems-test
> --rtems-tools=/home/zakonrockets/development/rtems/5 --rtems-bsp=pc-qemu
> /home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites
> --rtems-prefix=/home/zakonrockets/development/rtems/5
> > I don't quite know the name of my BSP currently I think it's pc 386 but
> it's not found. Am a correct to assume that it is?
> Yes, it should be the pc386 BSP.
> What do you mean by it is not found? If you search for "ticker.exe" do you
> find the testsuites/samples directory which should contain it?
> Best regards,
>    Jan
> > Il giorno mar 25 ago 2020 alle ore 16:17 <Jan.Sommer at dlr.de> ha scritto:
> > > -----Original Message-----
> > > From: users [mailto:users-bounces at rtems.org] On Behalf Of Gedare Bloom
> > > Sent: Tuesday, August 25, 2020 9:15 PM
> > > To: Zacchaeus Liang
> > > Cc: RTEMS Users RTEMS
> > > Subject: Re: BSP missing
> > > Hi Zack,
> > > On Tue, Aug 25, 2020 at 1:02 PM Zacchaeus Liang <zliang111 at gmail.com>
> > > wrote:
> > > > So I was able to build the bsp and all of the tests pass. I'm
> currently trying
> > > to build the hello world app.
> > > Gaming:~/development/app/hello$ ./waf configure --
> > > rtems=$HOME/development/rtems/5 --rtems-bsp=pc-qemu
> > > > Setting top to                           :
> > > > Setting out to                           :
> > > > (complete log in
> > > Is this from rtems-examples.git? Or something else?
> > pc-qemu exists in a configuration for the rtems-tester, but it is only
> a different way to execute the pc686 binaries on qemu instead via tftp on
> actual hardware (for more see here:
> https://git.rtems.org/rtems-tools/tree/tester/rtems/testing/bsps/pc-qemu.ini
> > I haven't encountered it somewhere else.
> > Best regards,
> >    Jan
> > > Please check out rtems-examples.git/README.waf for some assistance on
> > > how to use the rtems_waf to build an application.
> > > > Thanks
> > > > Zack
> > > > _______________________________________________
> > > > users mailing list
> > > > users at rtems.org
> > > > http://lists.rtems.org/mailman/listinfo/users
> > > users mailing list
> > > users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200826/dd74bdc3/attachment.html>
