On 28/8/20 1:31 am, Heinz Junkes wrote: > Is there a BSP for the Zynq-7000 based board cora-z7? > > Should the image of the zedboard be bootable on the cora z7-10 ? I am not about the zedboard, maybe. You could try `xilinx_zynq_zc702` with a suitable set of BSP configure options for memory. The ARM hard IP is the same on all the boards. Chris
