Python Issues on master baseline
Rick VanderWal
rvanderwal at bellsouth.net
Thu Aug 27 16:18:05 UTC 2020
Good Morning,
I just did a git pull on the rtems-source-builder repository and I am
now getting the following error when I execute:
../source-builder/sb-check
Traceback (most recent call last):
File "../source-builder/sb-check", line 23, in <module>
import sb.check
ImportError: No module named sb.check
I have also tried running:
../source-builder/sb-set-builder --list-bsets
and get:
Incorrect Source Builder installation
It appears to be an issue the Python module imports. (I'm not very
familiar with python) After some Googling, I've tried putting an
__init__.py in the sb directory. Running sb-check now, I get:
error: failed to load Linux host support
This was all done on Ubuntu Desktop 18.04 LTS. Python version is 2.7.17.
I also tried modifying the sb-check script to force it to run python3
(Version 3.6.9) and removed the __init__.py file, which also gave:
Adding the __init__.py file back had no effect.
It appears that the last commit on the repository changed how python was
executed, but I'm not sure if I have a python configuration issue on my
machine that just doesn't work with it.
Any guidance is definitely appreciated!
-Rick
