handle Fatal exception
Sebastian Huber
Mon Aug 31 17:58:59 UTC 2020
On 31/08/2020 19:06, Ярослав Лещинский wrote:
> sometimes I'm getting FATAL, like:
> *** FATAL ***
> fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
> is it possible to handle this exception, e.g. restart the whole system?
Yes, some BSPs do this by default in their fatal error extension. You
can customize the behaviour via an initial extension:
https://docs.rtems.org/branches/master/c-user/config/general.html#configure-initial-extensions
https://docs.rtems.org/branches/master/c-user/user_extensions.html#fatal-error-extension
