Problems in building rtems.
Vaibhav Gupta vaibhav.varodek at gmail.com
Thu Feb 6 04:28:09 UTC 2020
On Thu, Feb 6, 2020, 9:35 AM Ashwin Godbole <dev.godboleashwin at gmail.com>
wrote:
> Hi. My name is Ashwin. Im planning on participating in gsoc 2020. (But my
> interest in rtems is not confined to gsoc... I genuinely find this project
> interesting :P ).
> I'm new to RTEMS so I was trying to build myself a copy, according to the
> documentation at  https://docs.rtems.org/branches/master/user/start/
> I'm running a virtual box instance with Ubuntu running on it.
> At one step in the process, the docs instruct me to run the following
> command:
> ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5
> 5/rtems-sparc
> I'm facing issues here. My build keeps failing and I'm not getting
> anywhere. I keep getting build error that goes something like:
> error: building autoconf-2.69-X86_64-gnu-linux-1
> I'm attaching a screenshot of the exact error message.
The screenshot you shared has incomplete command. You haven't included '
--prefix ' option.
Check the 'rsb-report-autoconf.....txt' file for complete error report.
> Can someone assist me with this?
> Your help is much appreciated.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200206/d8bc63df/attachment.html>
