RTEMS Release Snapshot: 5.0.0-m2002 (06 Feb 2020)
Michael Davidsaver
mdavidsaver at gmail.com
Wed Feb 12 13:38:39 UTC 2020
This snapshot builds successfully for me on Debian 10 (amd64).
> ../source-builder/sb-set-builder --prefix /home/mdavidsaver/source/rtems/usr --rtems-bsp i386/pc386 5/rtems-i386
I did expect that these arguments would also build the RTEMS kernel, but this seem
not to be case. I also tried (based on some clearly obsolete notes) adding '--with-rtems'
which had no effect.
Is there a way to build the toolchain and kernel in one shot?
Am I missing a link to current RSB documentation?
I'd look further for this myself, but atm. I can't seem to load the rtems.org websites atm.
I see a redirect to www-new.rtems.org which has an expired Let's Encrypt cert.
On 2/5/20 6:39 PM, chrisj at rtems.org wrote:
> RTEMS Release Build - 5.0.0-m2002
> RTEMS 5 Release snapshot m2002 is avaliable for testing.
> It can be found at:
> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2002
> Please test and report any issues to the user at rtems.org or devel at rtems.org
> mailing lists or please raise a ticket.
> If you are part of the RTEMS testing program please build on your preferred
> host posting build and BSP test results to build at rtems.org.
> This is a development release and may have errors and be unstable.
> Thanks
> Chris
> users mailing list
> users at rtems.org
