Someone using CONFIGURE_HAS_OWN_INIT_TASK_TABLE?
Sebastian Huber
Fri Feb 14 07:10:39 UTC 2020
On 13/02/2020 16:37, Sebastian Huber wrote:
> Hello,
> I would like to revisit this configuration clean up opportunity:
> On 09/04/2019 14:55, Sebastian Huber wrote:
>> On 09/04/2019 14:50, Joel Sherrill wrote:
>>> On Tue, Apr 9, 2019, 2:08 AM Sebastian Huber
>>> <sebastian.huber at embedded-brains.de
>>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>> Hello,
>>> is the CONFIGURE_HAS_OWN_INIT_TASK_TABLE actually used in
>>> application
>>> configurations?
>>> After sending that last email, this one is more likely to be used
>>> than any of the others.
>>> Not responding to an email on the list doesn't mean it isn't used.
>>> If this option is deleted, the comparable POSIX one must go. then
>>> you get a single init task of one or both APIs.
>> This one actually doesn't cause great pain to me at the moment. I
>> just wanted to know if it actually used. Removing it would simplify
>> things a bit, but not much.
> The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and
> CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_*
> configuration options. I would like to remove them to simplify the
> configuration. It would be possible to keep them and still simplify
> the configuration, however, I doubt that these options were used at all.
> Any objections to remove them?
I plan to remove them next week:
https://devel.rtems.org/ticket/3873
https://devel.rtems.org/ticket/3874
