Print stack info using rtems_stack_checker_report_usage_with_plugin()
Joel Sherrill
joel at rtems.org
Fri Jan 3 21:04:49 UTC 2020
On Fri, Jan 3, 2020, 2:58 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Dec 12, 2019 at 7:08 AM Joel Sherrill <joel at rtems.org> wrote:
>> On Thu, Dec 12, 2019, 7:21 AM Fernando Domínguez Pousa <fdpousa at gmv.com>
>> wrote:
>>> *From:* Joel Sherrill [mailto:joel at rtems.org]
>>> *Sent:* 10 December 2019 17:36
>>> *To:* Fernando Domínguez Pousa <fdpousa at gmv.com>
>>> *Subject:* Re: Print stack info using
>>> On Tue, Dec 10, 2019, 8:37 AM Fernando Domínguez Pousa <fdpousa at gmv.com>
>>> wrote:
>>> Hi all,
>>> I’m interested in getting stack information via an UDP message with an
>>> ASCII log trace inside. Basically, I cannot get the information using a
>>> printf. I found the function
>>> rtems_stack_checker_report_usage_with_plugin(rtems_printer* printer) in
>>> order to get the information and send it using my UDP log function. So
>>> first of all I created a function called logPlugin (I used as exampled the
>>> plugin at printf_plugin.c):
>>> static int logPlugin(void *context, const char *format, va_list ap)
>>> (void) context;
>>> return addLog(INFO, STACK,format, ap); /* First two arguments are used
>>> to classify message at reception*/
>>> Then at rtems_stack_checker_report_usage_with_plugin calling scope:
>>> rtems_printer printer;
>>> printer.context = NULL;
>>> printer.printer = logPlugin;
>>> rtems_stack_checker_report_usage_with_plugin(&printer);
>>> It is important to say that addLog puts the message in a circular buffer
>>> that other task will read and send the content using UDP.
>>> When stack checker report usage is called, only the information header
>>> is printed: " STACK USAGE BY THREAD\n"
>>> "ID NAME LOW HIGH CURRENT
>>> AVAIL USED\n"
>>> Next, stack values are not printed correctly and I can only get a value
>>> that is constant and equal to the same memory location (in decimal). It is
>>> a correct guide to implement this? I do not know how to use the printer
>>> struct context variable, can this cause my problem?
>>> Did you add CONFIGURE_ENABLE_STACK_CHECKER?
>>> Yes, it was enabled.
>>> Also it would be handy to have methods for obtain cpu and stack usage
>>> without relying on the printf hook
>>> I developed a code to gather all the tasks stack information into a
>>> struct that can be retrieved via function. Then I pack this struct and sent
>>> it via Ethernet. Can I add my code to check.c in order to retrieve stack
>>> information without print it? Is this an intersesting feature for the
>>> community?
>> Yes it is interesting. File a ticket so there is one to track this
>> addition.
>> It also will need a test and some documentation. I'm not sure how the
>> test will check the function behaves correctly.
>> Looking forward to seeing your submission.
> We've had this feature request before. It was somewhat captured in
> https://devel.rtems.org/wiki/Developer/Projects/Open/StackChecker
> and the related:
> https://devel.rtems.org/wiki/Developer/Projects/Open/CPU_Statistics
> It's not clear it is enough work for a GSoC, but it seems too much work
> for someone to do voluntarily :)
I'd love to see those pages deleted and turned into tickets. <Hint>
>> --joel
>>> Regards,
>>> Thanks in advance,
>>> Regards,
>>> *Fernando Domínguez Pousa *Ingeniero de Software
>>> Software Engineer
>>> GMV
>>> Isaac Newton, 11
>>> P.T.M. Tres Cantos
>>> E-28760 Madrid
>>> Tel. +34 91 807 21 00
>>> Fax +34 91 807 21 99
>>> www.gmv.com
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.facebook.com_infoGMV&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=TVgsYD5kZtUVH9LulD6BpnRsdJjK7KKhwm0gExv79V0&e=>
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.twitter.com_infoGMV-5Fes&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=AKhuDTIEG9B5SSppSI9W2IZbCtlVN6Xxghmhqw_8xrs&e=>
>>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__plus.google.com_-2BGmvcompany&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=aH_sTC6ItBsWu6XvQPqgmMi4brzX7wBHmPqFQ2FbfSc&e=>
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.youtube.com_infoGMV&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=LeXn3Vd6znq0lx28JCcO0BUCbRxzg36aodelZfSy_QE&e=>
>>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__www.linkedin.com_company_gmv&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=qQvn0q84_7QaJIvkgK7wpqkfzr7YoJNDa9KIA6w0TVQ&e=>
>>> <http://www.gmv.com/en/RSS>
>>> <http://www.gmv.com/blog_gmv/language/en/>
>>> P Please consider the environment before printing this e-mail.
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=dGxmP2gK5vUyNRX5UQVoMbmLLQ1K6M-QpFkFJfVYVEY&e=>
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200103/282dfb49/attachment-0001.html>
