Remote Debugging on Zynq Boards
Vishav.Vishav at dlr.de Vishav.Vishav at dlr.de
Tue Jan 7 10:58:37 UTC 2020
Hi,
I want to remotely debug an RTEMS application on Zynq based board. I have been following link:
https://docs.rtems.org/branches/master/user/exe/debugging.html<https://docs.rtems.org/branches/master/user/exe/debugging.htm>
I am particularly interested in Libdebugger Executable Debugging. I built the rtems-libbsd and found the debugger01 application. I am able to boot this application on the target board using tftpboot. This results in gdb server on the board. From the host computer, I run arm-rtems-5-gdb  myapp. I am able to connect to server using target remote 192.168.178.1:1122. I set the breakpoint using break Init and then c to continue. The host machine displays continuing but never breaks at breakpoint.
Can someone help me know if this is correct way to debug an RTEMS application?
Thanks & Regards
Vishav
URL: <http://lists.rtems.org/pipermail/users/attachments/20200107/b888ff05/attachment.html>
