USB device mode
Tony Whittam
tony.whittam at rapttouch.com
Fri Jan 10 15:57:42 UTC 2020
Hi,
Does anyone know of an example project with a USB device implemented with
rtems-libbsd?
I have built rtems-libbsd for the realview_pbx_a9_qemu and for the
altcycv_devkit. The USB examples in the testsuite all appear to be USB
host-mode tests. What I want to do is to create a system that will present
a USB composite device that I can connect to a USB host. The composite
device is to have a USB bulk IN endpoint, a USB bulk OUT endpoint and a USB
HID IN endpoint. I'm trying to find out whether I can do this on RTEMS. I
have all the relevant USB descriptors from my implementation that uses USB
gadgets on Linux. I want to port the application to an RTOS.
Thanks,
Tony
Confidentiality Notice:
The information contained in this message,
including any attachments hereto, may be confidential and is intended to be
read only by the individual or entity to whom this message is addressed. If
the reader of this message is not the intended recipient or an agent or
designee of the intended recipient, please note that any review, use,
disclosure or distribution of this message or its attachments, in any form,
is strictly prohibited. If you have received this message in error, please
immediately notify the sender and/or Rapt Touch Ltd via email at
info at rapttouch.com <mailto:info at rapttouch.com> and delete or destroy any
copy of this message and its attachments.
URL: <http://lists.rtems.org/pipermail/users/attachments/20200110/eb7decc1/attachment.html>
