Problem in Building BSP
Niteesh
gsnb.gn at gmail.com
Sun Jan 12 16:22:14 UTC 2020
Maybe, because you don't have the necessary packages installed.
Go through this
https://docs.rtems.org/branches/master/user/hosts/posix.html#linux
and make sure you have installed the required packages.
On Sun, Jan 12, 2020 at 9:31 PM Prithvi Chakravarthy <
prithvichakravarthy at gmail.com> wrote:
> Hi,
> I've been trying to set up RTEMS. So far I have been following the
> documentation and i when i building BSP.
> When I entered the following command:
> HOME/quick-start/src/rtems/configure \
> > --prefix=$HOME/quick-start/rtems/5 \
> > --enable-maintainer-mode \
> > --target=sparc-rtems5 \
> > --enable-rtemsbsp=erc32 \
> > --enable-tests
> I had the following code as output:
> /home/prithvi/quick-start/src/rtems/configure: line 472: sed: command not
> found
> /home/prithvi/quick-start/src/rtems/configure: line 471: expr: command not
> found
> found
> /home/prithvi/quick-start/src/rtems/configure: line 486: sed: command not
> found
> : error: cannot create .lineno; rerun with a POSIX shell
> Any help would be highly appreciated.
> Regards,
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200112/df81fd8d/attachment.html>
