Problem in Building BSP
Joel Sherrill
joel at rtems.org
Sun Jan 12 17:00:25 UTC 2020
On Sun, Jan 12, 2020, 10:22 AM Niteesh <gsnb.gn at gmail.com> wrote:
> Maybe, because you don't have the necessary packages installed.
> Go through this
> https://docs.rtems.org/branches/master/user/hosts/posix.html#linux
> and make sure you have installed the required packages.
This is definitely the right answer but sed is a very basic utility. I'm
not sure how you would get any Linux installation without it.
Check you PATH to make sure /bin and /use/bin are in it. A typo prepending
the RTEMS tools to your PATH could have messed it up.
Try a new shell and do "which sed" or "type sed". I expect it is there. If
not, you have found a way to get an OS install with less installed than we
have seen. :)
--joel
> On Sun, Jan 12, 2020 at 9:31 PM Prithvi Chakravarthy <
> prithvichakravarthy at gmail.com> wrote:
>> Hi,
>> I've been trying to set up RTEMS. So far I have been following the
>> documentation and i when i building BSP.
>> When I entered the following command:
>> HOME/quick-start/src/rtems/configure \
>> > --prefix=$HOME/quick-start/rtems/5 \
>> > --enable-maintainer-mode \
>> > --target=sparc-rtems5 \
>> > --enable-rtemsbsp=erc32 \
>> > --enable-tests
>> I had the following code as output:
>> /home/prithvi/quick-start/src/rtems/configure: line 472: sed: command not
>> found
>> /home/prithvi/quick-start/src/rtems/configure: line 471: expr: command
>> not found
>> found
>> /home/prithvi/quick-start/src/rtems/configure: line 486: sed: command not
>> found
>> : error: cannot create .lineno; rerun with a POSIX shell
>> Any help would be highly appreciated.
>> Regards,
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200112/c1a7f937/attachment.html>
