Error While building BSP | erc32 | sparc-rtems-4.11.3
Bran S
archsbran at gmail.com
Fri Jan 24 18:56:52 UTC 2020
Hi Guys,
I am trying to build and run rtems.
Followed the steps as mentioned at
https://docs.rtems.org/branches/master/user/start/index.html
Getting this error while doing make as mentioned here
https://docs.rtems.org/branches/master/user/start/bsp-build.html
gmake[2]: Entering directory
'/home/user45/quick-start/build/b-erc32/sparc-rtems4.11/c/erc32'
gmake[2]: *** No rule to make target 'all'. Stop.
gmake[2]: Leaving directory
gmake[1]: *** [Makefile:286: all-recursive] Error 1
gmake[1]: Leaving directory
'/home/user45/quick-start/build/b-erc32/sparc-rtems4.11/c'
make: *** [Makefile:410: all-recursive] Error 1
Full logs are at https://justpaste.it/7ao05
This was my configure command:
$HOME/quick-start/src/rtems-4.11.3/configure
--prefix=$HOME/quick-start/rtems/4.11 --enable-maintainer-mode
--target=sparc-rtems4.11 --enable-rtemsbsp=erc32 --enable-tests
My $PATH var includes: /home/user45/quick-start/rtems/4.11/bin
As the error mentions No rull to make target 'all'
I checked the
'/home/user45/quick-start/build/b-erc32/sparc-rtems4.11/c/erc32' directory
and it doesn't contain any Makefile. Although a make directory is present
in there.
Any ideas about what is causing this ?
Thanks
URL: <http://lists.rtems.org/pipermail/users/attachments/20200125/16578796/attachment.html>
