Error While building BSP | erc32 | sparc-rtems-4.11.3
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Jan 27 10:00:50 UTC 2020
On 24/01/2020 19:56, Bran S wrote:
> Hi Guys,
> I am trying to build and run rtems.
> Followed the steps as mentioned at
> https://docs.rtems.org/branches/master/user/start/index.html
> Getting this error while doing make as mentioned here
> https://docs.rtems.org/branches/master/user/start/bsp-build.html
> gmake[2]: Entering directory
> '/home/user45/quick-start/build/b-erc32/sparc-rtems4.11/c/erc32'
> gmake[2]: *** No rule to make target 'all'. Stop.
> gmake[2]: Leaving directory
> gmake[1]: *** [Makefile:286: all-recursive] Error 1
> gmake[1]: Leaving directory
> '/home/user45/quick-start/build/b-erc32/sparc-rtems4.11/c'
> make: *** [Makefile:410: all-recursive] Error 1
> Full logs are at https://justpaste.it/7ao05
> This was my configure command:
> $HOME/quick-start/src/rtems-4.11.3/configure
> --prefix=$HOME/quick-start/rtems/4.11 --enable-maintainer-mode
> --target=sparc-rtems4.11 --enable-rtemsbsp=erc32 --enable-tests
> My $PATH var includes: /home/user45/quick-start/rtems/4.11/bin
> As the error mentions No rull to make target 'all'
> I checked the
> directory and it doesn't contain any Makefile. Although a make directory
> is present in there.
> Any ideas about what is causing this ?
> Thanks
Hello Bran,
I noted that you have a RTEMS 4.11 toolchain. But it seems that you use
the instructions for the RTEMS master (which has a Version 5). Did you
use a matching RTEMS 4.11 branch for your build?
Best regards
Christian
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
