Problem building or1ksim
Charles Manning
cdhmanning at gmail.com
Tue Jan 28 23:37:17 UTC 2020
Hello
In my quest for an RTEMS development environment that works with a
simulator, I thought I would try the HoW To at
http://heshamelmatary.blogspot.com/2015/02/howto-1-build-or1k-rtems-toolchain-via.html
This is based on 4.11, but I switched it to 5 by just substituting 5
everywhere there's 4.11.
That worked fine until getting to the step for building or1ksim.
Can anyone explain a way around this? Thanks
Charles
charles at yaffs-dev:~/development/rtems/src/rtems-source-builder/bare/config$
../../source-builder/sb-set-builder --log=l-or1ksim.txt
--prefix=$HOME/development/rtems/5 devel/or1ksim
RTEMS Source Builder - Set Builder, 5 (599c4d7c87fa)
Build Set: devel/or1ksim
config: devel/or1ksim-1.1.0.cfg
package: or1ksim-1.1.0-x86_64-linux-gnu-1
Creating source directory: sources
download: https://github.com/openrisc/or1ksim/archive/or1k-master.zip
-> sources/or1k-master.zip
redirect: https://codeload.github.com/openrisc/or1ksim/zip/or1k-master
downloading: sources/or1k-master.zip - 2.2MB
error: hash: or1k-master.zip: insecure: md5
Build FAILED
See error report: rsb-report-or1ksim-1.1.0-x86_64-linux-gnu-1.txt
Build Set: Time 0:00:01.735557
Build FAILED
