How do you plan before starting to code ?
Richi Dubey richidubey at gmail.com
Thu Jul 9 08:22:25 UTC 2020
Hi,
I understand. I'll learn how to use Doxygen and put it in my codes. Thank
you.
On Thu, Jul 9, 2020 at 12:43 PM Sebastian Huber <
> Hello Richi,
> we use Doxygen to document the software design. Maybe you can write your
> high-level description with it. This way it is integrated already
> integrated in the sources. You can use @dot for graphs and @msc for
> message sequences.
> I would document the data structures and the invariants of the data
> structures. I would also try to write code which checks that the
> invariants are satisfied. This can be used in _Assert() and RTEMS_DEBUG
> blocks.
> I would also write test cases. You can already run the test cases with:
> https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#arbitrary-processor-affinity-priority-smp-scheduler
> There should be test cases which would fail with the Linux push and pull
> scheduler.
> You should identify the key scheduler operations (e.g. block and
> unblock) and write a high level description of the algorithms used for
> these operations in some sort of pseudo code.
URL: <http://lists.rtems.org/pipermail/users/attachments/20200709/bc17e9ce/attachment-0001.html>
