Header missing
Gedare Bloom
gedare at rtems.org
Thu Jul 9 15:10:41 UTC 2020
On Thu, Jul 9, 2020 at 9:08 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Jul 6, 2020 at 3:56 PM Daniela Oliveira <oliveiradad at gmail.com> wrote:
> > > Hi guys,
> > > I have built a RTEMS 5 sparc, as docs.rtems.org tutorial. When I had built the C/C++ project,
> > > I have found a missing header in bsp.h, the bspopts.h. I have no idea why this header appeared inside the DEV directory.
> > > I rewrote the header bsp.h path, <bspopts.h> for <dev/bspopts.h>
> > >Then I ask: Is this normal?
> No, this is not normal.
> .../b-erc32-5$ find . -name bspopts.h
> ./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include/bspopts.h
> Can you identify what tutorial did you follow, and whether you changed
> any steps?
> Do you check out the rtems.git/5 branch?
Is this dev/bspopts.h in your installed tree?
> > > Best regards,
> > > Daniela.
> > Enviado do Email para Windows 10
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
