Header missing
Joel Sherrill
joel at rtems.org
Thu Jul 9 15:12:24 UTC 2020
On Thu, Jul 9, 2020 at 10:10 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Jul 9, 2020 at 9:08 AM Gedare Bloom <gedare at rtems.org> wrote:
> > On Mon, Jul 6, 2020 at 3:56 PM Daniela Oliveira <oliveiradad at gmail.com>
> wrote:
> > > > Hi guys,
> > > > I have built a RTEMS 5 sparc, as docs.rtems.org tutorial. When I
> had built the C/C++ project,
> > > > I have found a missing header in bsp.h, the bspopts.h. I have no
> idea why this header appeared inside the DEV directory.
> > > > I rewrote the header bsp.h path, <bspopts.h> for <dev/bspopts.h>
> > > >Then I ask: Is this normal?
> > No, this is not normal.
> > .../b-erc32-5$ find . -name bspopts.h
> > ./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include/bspopts.h
> > Can you identify what tutorial did you follow, and whether you changed
> > any steps?
> > Do you check out the rtems.git/5 branch?
> Is this dev/bspopts.h in your installed tree?
Installed being a keyword here. Did you do "make install"? You need to be
building against an installed image.
> > > > Best regards,
> > > > Daniela.
> > > Enviado do Email para Windows 10
> > > _______________________________________________
> > > users mailing list
> > > users at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200709/91ec10ba/attachment.html>
