Where to define CPU_SIMPLE_VECTORED_INTERRUPTS for RISC-V?
Schweikhardt, Jens (TSPCE3-TL4)
Jens.Schweikhardt at tesat.de
Tue Jun 2 08:06:54 UTC 2020
Hello world,
we are using a customized RV32IMAF CPU with RTEMS and need to handle interrupts.
I'm new to configuring low level things such as this and need a bit of guidance where goes what.
I build using the RTEMS source builder.
It appears that for RISC-V a value for CPU_SIMPLE_VECTORED_INTERRUPTS is not defined, and thus treated as FALSE.
Other CPUs, such as sparc, define it in cpukit/score/cpu/sparc/include/rtems/score/cpu.h.
Q: Should I simply add a macro definition to cpukit/score/cpu/riscv/include/rtems/score/cpu.h or is there
a better (proper) way, say, passing it as an argument to sb-set-builder or sb-bootstrap or the configure script building the bsps?
Jens
________________________________
Tesat-Spacecom GmbH & Co. KG
Sitz: Backnang; Registergericht: Amtsgericht Stuttgart HRA 270977
Persoenlich haftender Gesellschafter: Tesat-Spacecom Geschaeftsfuehrungs GmbH;
Sitz: Backnang; Registergericht: Amtsgericht Stuttgart HRB 271658;
Geschaeftsfuehrung: Dr. Marc Steckling, Kerstin Basche, Ralf Zimmermann
[banner]
