RTEMS Release Snapshot: 5.0.0-m2003 (03 Mar 2020)
Chris Johns
chrisj at rtems.org
Thu Mar 5 07:08:07 UTC 2020
On 2020-03-05 15:35, Michael Davidsaver wrote:
> On 3/4/20 12:50 AM, Chris Johns wrote:
>> However libbsd for the PC will not build for the PC. The release is using the
>> 5-freebsd-12 branch of libbsd and this branch does not had the PC patches that
>> master has and we cannot back port those patches because master and 5-freebsd-12
>> use different FreeBSD branches.
> So none of the x86 BSPs currently has a working network stack with rtems5?
I saw recently patches for the PC were pushed to the master branch of
libbsd to fix a build problem. I assume this has also made the stack
work. I have not tested it. The RSB builds the 5-freebsd-12 branch as
this is the branch we will release with RTEMS 5.
Also the legacy stack may work. This is available with the
--enable-networking option to RTEMS's configure.
