RTEMS Release Snapshot: 5.0.0-m2003 (03 Mar 2020)
Michael Davidsaver
mdavidsaver at gmail.com
Fri Mar 6 02:46:28 UTC 2020
On 3/4/20 11:08 PM, Chris Johns wrote:
> On 2020-03-05 15:35, Michael Davidsaver wrote:
>> On 3/4/20 12:50 AM, Chris Johns wrote:
>>> However libbsd for the PC will not build for the PC. The release is using the
>>> 5-freebsd-12 branch of libbsd and this branch does not had the PC patches that
>>> master has and we cannot back port those patches because master and 5-freebsd-12
>>> use different FreeBSD branches.
>> So none of the x86 BSPs currently has a working network stack with rtems5?
> I saw recently patches for the PC were pushed to the master branch of libbsd to fix a build problem. I assume this has also made the stack work. I have not tested it. The RSB builds the 5-freebsd-12 branch as this is the branch we will release with RTEMS 5.
> Also the legacy stack may work. This is available with the --enable-networking option to RTEMS's configure.
How would you go about building a toolchain for pc686 with the legacy stack using RSB?
(my track record at guessing CLI arguments isn't good)
