Error when building rtems
Mingyu Li
lmy2010lmy at gmail.com
Sun Mar 8 14:51:02 UTC 2020
Hi Richi,
What is the host system that you are using to build RTEMS?
Suppose you are using Ubuntu, here is what you can do:
sudo apt-get install texinfo
ln -s `which makeinfo` /usr/bin/makeinfo
Hope this helps!
Bests,
Mingyu
G. S. Niteesh <gsnb.gn at gmail.com> 于2020年3月8日周日 下午10:11写道:
> Which documentation are you referring to?
> you should either use
> https://docs.rtems.org/branches/master/user/start/index.html
> or
> https://docs.rtems.org/branches/master/user/installation/index.html (Refer
> to development and kernel installation page)
> On Sun, Mar 8, 2020 at 4:14 PM Richi Dubey <richidubey at gmail.com> wrote:
>> Hey everyone,
>> (Sorry if this is a repost, I don't even if the earlier one went or not)
>> I am new to RTEMS development environment and I needed someone's help.
>> I downloaded rtems and the rtems source builder usnig curl command given
>> in documentation. But now when I am running
>> ../source-builder/sb-set-builder --source-only-download 5/rtems-sparc
>> inside the rtems-source-builder-4.1103/rtems, I am getting the following
>> error:
>> RTEMS Source Builder - Set Builder, 4.11.3
>> error: exe: not found: (__makeinfo) /usr/bin/makeinfo
>> error: host build environment is not set up correctly
>> Build FAILED
>> Can someone help me out with this please?
>> Thanks,
>> Richi.
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200308/d62f4fe6/attachment.html>
