Error when building rtems
G. S. Niteesh
gsnb.gn at gmail.com
Sun Mar 8 14:11:08 UTC 2020
Which documentation are you referring to?
you should either use
https://docs.rtems.org/branches/master/user/start/index.html
or
https://docs.rtems.org/branches/master/user/installation/index.html (Refer
to development and kernel installation page)
On Sun, Mar 8, 2020 at 4:14 PM Richi Dubey <richidubey at gmail.com> wrote:
> Hey everyone,
> (Sorry if this is a repost, I don't even if the earlier one went or not)
> I am new to RTEMS development environment and I needed someone's help.
> I downloaded rtems and the rtems source builder usnig curl command given
> in documentation. But now when I am running
> ../source-builder/sb-set-builder --source-only-download 5/rtems-sparc
> inside the rtems-source-builder-4.1103/rtems, I am getting the following
> error:
> RTEMS Source Builder - Set Builder, 4.11.3
> error: exe: not found: (__makeinfo) /usr/bin/makeinfo
> error: host build environment is not set up correctly
> Build FAILED
> Can someone help me out with this please?
> Thanks,
> Richi.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200308/59a0ff33/attachment.html>
