Error when building rtems
Gedare Bloom
gedare at rtems.org
Mon Mar 9 16:08:44 UTC 2020
On Sun, Mar 8, 2020 at 4:44 AM Richi Dubey <richidubey at gmail.com> wrote:
> Hey everyone,
> (Sorry if this is a repost, I don't even if the earlier one went or not)
> I am new to RTEMS development environment and I needed someone's help.
> I downloaded rtems and the rtems source builder usnig curl command given in documentation. But now when I am running ../source-builder/sb-set-builder --source-only-download 5/rtems-sparc inside the rtems-source-builder-4.1103/rtems, I am getting the following error:
> RTEMS Source Builder - Set Builder, 4.11.3
> error: exe: not found: (__makeinfo) /usr/bin/makeinfo
> error: host build environment is not set up correctly
> Build FAILED
> Can someone help me out with this please?
Niteesh makes a good point: what documentation did you use to
determine how to build and run RTEMS?
I see a version mismatch above. You are specifying 5/rtems-sparc from
something downloaded that indicates version 4.11.
> Thanks,
> Richi.
> users mailing list
> users at rtems.org
